bolting to floor
then drill upwards i guess? i know where approximately where in the inside id like to but as in knowing where it is from underneath the car?
If you must just cut a small slit to put the punch through. You want a good solid mark and the carpet will probably have you swatting the punch too much to make it easy.
im going to do it opposite probably. take out all the carpet and punch from under the car. i doubt id find a little dent under teh car. time to go experiment
thanks for your help guys!
Why would you try from under the car when you need to know where to run bolts through from the inside? Just pull the carpet, look at the floorboard and remember its features (humps/depressions/etc) and get under the car and look for them. Then drill... I don't see why this should be a complicated process :p
****. the seatbelts are keeping me from removing the plastic panels to get the carpet out. big torx screwdriver needed. and ofcource its christmas so no hardware stores open. ugh. ***** waiting
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
7
646
No reason you can't get the sound you want with ported or passive radiator but if you have no ability to tune the mass of the passives you will...
7
taintedplay
taintedplay
dallas
thorshammer1
SlugButter
    Mar 28, 2024
SlugButter
    Mar 28, 2024
Latest topics
