24's or 26's
theking
us
Looking to go with 24's at least possibly 26's if i can get away with no rubbing without adding a leveling kit since its only 1" difference from the front and the back height difference, and the smallest leveling kit i have found is 2" and dont want it to sit up higher in the front than the back.
i measured from the ground to the fender i have 33" in the front and 34" in the back.
Then i measured from front to back in the wheel wells as in horiziontal in the front and back i got 36" so would i rub with 26's
These are some pics of the wheel wells with stock 17's with 275/60/17 tires on it
What do you think
will 26's rub, and i dont want it to look like a donk i just want the rim to fill the whole wheel well or most of it i dont want to get 24's and regret down the road not getting 26's and no i dont want to drop it at all
look above for the rims i am looking at, how much will the 24's fill up of the wheel well, and will i regret not getting 26's
with rims and tires what would the whole diameter be of the rim and tire 24" rim plus 2" low pros or what so from top to bottom looking at 28"
well i am not sure if 26's will look out of place and dumb since its 2wd and doesnt sit up high in the first place, and also not sure if 26's will rub or not
whats the thickness on most low pro tires
theking
theking
us
theking
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
