Need help designing enclosure for 18" BTL
  • 6
mk_
Tempe, AZ
Hey guys,
My next build is with a FI BTL 18" fully loaded.
These are the dimensions I would like:
HEIGHT: 22 inches
WIDTH: 37 inches
DEPTH: 21 inches
I was throwing around the idea of having a slot port on the top of the enclosure like this sad drawing portrays:
Tuning I want to be around 35hz. Any box calculators I can use to determine the cuts for a box like this?
Or any other suggestions are welcome too.
Thanks,
Michael
It will be going in a Dodge Stealth.
These dimensions will fit, just not sure how to calculate the box with the port on top.
Well, I currently have a slot port vertical behind the drivers seat. I was looking for something different, hence the top horizontal slot port idea. Crunching numbers it looks like I might not be able to fit it. I have 22" height to work with, 18" approx goes to the speaker alone, another 1.5" for thickness of mdf, leaving me with a small port width...
So I don't think that is going to work.
Port on both sides does sound pretty intriguing however..... not sure where to even start with it though..
Open to ideas!!!
Michael
^^^The way you want to do it with the port above the sub won't work...it's just too skinny of a port. I've been designing a few boxes with the two ports, one on each side, for one sub. You're got a little over 8.2ft^3 to work with, which is plenty since you'll probably end up with right around 6ft^3 after all displacement.
11
390
558
https://youtube.com/@SaabUnleashed?si=-8qdxpYY0yGzrMsL Here you go. This guy does android head unit reviews. His reviews are how I found my...
7
836
If you want 5 channels of amplification you just need 5 channels of amplification. You can do this with 5 amps or 1, depends on budget and space...
mk_
mk_
Tempe, AZ
iamamp3pimp
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
Latest topics
