Jump to content
Sign in to follow this
leong6gtp
question about audio buzz
Recommended Posts
So i have a xbox 360 wired to my pioneer headunit. But when i turn it on there is a faint buzzing sound from my speakers. What could be the culprit of that? I breifly heard about interference or seomthing with the wires but im not sure. Just to make sure i plugged in my PSP to it too and there was no buzzing noise.
BTW anyone here install a battery relocation kit before? I have a summit racing one im gonna install and wondeirng if anyone has any tips. Thanks for the help!
Share this post
Link to post
Share on other sites
xbox might be introducing ground loop.
2003 chevy s-10 ext. cab
hu: jvc kd-avx1
precision power 356cs components
front amp: infinity 475a
sub: diamond audio d6 10d4
enclosure: 1.1 cubes ported tuned @ 31hz
sub amp: JL G1700
Share this post
Link to post
sorry im not really familier with this. what does that mean? is there anyway to stop it?
Share this post
Link to post
Do you have the 360 plugged into a power inverter?
95 Sonoma Ext Cab 4.3L 5spd, Dual alts Tenney 270 amp alternator and 240 amp H.O.alts, 4 DEKA AGM batteries
Pioneer deh8400 rsd250.2 powering Infinity Kappa60.5 comps and Morel coaxials
7.2 cube net wall 2 crossfire XSv215s and 4 bb2400.1s.
Daily Driver: 1995 Buick Park Avenue "leather couch on wheels"
JVC KD-HDR60 Aura RPM2300 on Opti5.1 comps and Planet Audio zr300.4 bridged on Morel Ultimo 6X9's
REFS: AMPJUNKIELIKEME, SERJR711, ZEUSILICIOUS
Share this post
Link to post
you could buy a ground loop isolator, and put it on the audio rca's.
hu: jvc kd-avx1
sub amp: JL G1700
Share this post
Link to post
so basically take my rca's audio and ground them like where i grounded my inverter?
Share this post
Link to post
no. go to radio shack and buy a ground loop isolator. it explains itself after that.
hu: jvc kd-avx1
sub amp: JL G1700
Share this post
Link to post
ok thanks a lot for the help. :)
Share this post
Link to post
ok so i put in the ground loop isolator and it still buzzes. the way i have my set up the wires coming form the 360 are hooked to an extension terminal then theres a cable that runs all the way to the front in the glove box which is plugged into a AV switcher then goes to my HU. mabe i should put the ground loop isolator right before my 360 plugs into the AV swicther? or put it in when it comes out of the AV switcher and to the HU.
Share this post
Link to post
So i wired in the ground loop isolator before the wires go to the HU. Im thinking it ahs something to do wire the power wire going back to my inverter. i ahve a switch between the inverter as well.
Share this post
Link to post
Create a free account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's free & easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
