Easy question
  • 2
Streetz
15
Chicago
I had to rewire my car, originally I had it going through the door jam because I didn't want to bother with the firewall. Everytime I open and closed the door in would pinch the cable and it started to frey(sp?). So I rewired it correctly, going through the firewall to the trunk.
The positive cable would not reach to my trunk. I had a second wiring kit laying around so what I did is I cut it and used the second fuse holder to extend the connection so it would reach. My question is, is having 2 fuses on the positive cable harmful? Both sets of cable are 4 gauge. I realise there is probably loss of power, but is it bad? Should I find a longer single wire and rerun that instead?
I will be getting a new car spring of 09 so I guess you can call this a temporary solution until then, but still wanted input on it. Thanks.
lol me... i would just tape that bish togther and forget about the fuse, but people also think i am gonna blow myslef up one day so dont do as i say. . . .. . .
Nothing to add to this, Just wanted to say good luck and that I miss MiniDisc. OH!! Is that a Japanese Radio Tuner or does it get stations in the US?
588
That would be fantastic! Id love to see the skills involved here. It always intrigues me to see some customizing from small and detailed to large...
380
The AudioControl LC7i has a maximum output voltage of up to 8.5volts. It can output up to 8.5 volts which is more than a typical aftermarket head...
Streetz
Streetz
Chicago
Streetz
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
