Which subs to get for my amp: eD or Infinity?
both will be awesome. i know for a fact that the perfect goes VERY low..about the same as my E15k when i had it. both will sound good, but IMO, the e10k is a better deal. they can take more power when you plan to upgrade to a bigger amp. you have about 300 watts, flip a coin;) //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
They both will sound good, however, I would choose the K's for several reasons. Build quality being the main. I've owned 4 Perfects in the past and I've installed Shiva's that have blown them away in SQ and SPL.
You said the subs are dual 4 ohm. Keep in mind that this means you have to wire them in series/parallel which will give you 4 ohms. Yes, the amp...
834
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
4K
I recommend wiring to the 2 ohm load on the amp you stated you have, or you can wire to an 8 ohm load for amp stability. You can wire one sub to...
https://www.the12volt.com/caraudio/subwoofer-wiring-diagrams.asp?Q=2&I=41
16
swingking03
swingking03
Tampa, FL
Mark_ab
MrG
    Apr 18, 2024
MrG
    Apr 18, 2024
