What are the advantages of Bandpass?
Pros:
Easy to direct output.
Higher power handling.
Keeps speaker free from debris.
Proper design leads to great low frequency extension.
Cons:
Usually a large enclosure.
Hides distortion so you can't detect possible damage to your driver.
Overall, very hard on the driver.
Very hard to build, and design.
- Steve
the bottom line is this: unless you plan to build your own bandpass box and put a ton of hours of design and work into it, do not get one. you especially dont want a pre-fab bandpass box.
-nate
Well when I first got into car audio, I got a pre fabbed bandpass for my bazooka subs. (They weren't all that bad actually, bazooka only has a bad rep cause of the tube subs, other than that, bazooka is pretty good) I can tell you, only get a bandpass if you want pure SPL. It ruins any kind of SQ (unless built directly for that sub) but makes almost any kind of driver really loud.
4th order bandpass has a good transient response, power handling, and a lower cutoff frequency.
A 6th order bandpass has very nice power handling within its passband, but outside of the passband it's power handling is poor- the driver relies on its suspension under the passband (just like ported)...not too good of a transient response as well...
Originally posted by snova031 4th order bandpass has a good transient response, power handling, and a lower cutoff frequency.
Thanks for all the responses.
Do you know a web site where i can get instructions on how to construct a proper bandpass enclosure. Im just curious.
is this a ported enclosure or a 4th order? If 4th and tuned to 33hz, unless specifically designed to do that, it wont have any bandwidth. It might...
I’m going to stick with the 4th order bandpass for now and see if it can improve it. The bandpass actually plays 100 rebased songs good.
I hope you didn’t misInterpret my last message.. I was excited that I actually understand what you’re talking about… Lol! I will level with you. I...
14
If you're serious about an 18 in the trunk front firing/trunkwalled go ahead. At least you got electrical covered /w/ a 600rms sub I'd wager. If...
16
NitroDuck
20 inches, Nothin less
NitroDuck
Mansfield, MA
ss3079
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
