8ga wire for subs?
5.7RAM
IL
Good,bad? I bought my type r used and figured I would open up the box and see how it was wired...well. I found 10gauge wire connecting the two VC's and 16ga to the terminal on the box. I wasnt too happy with this so I decided to take a trip to the the local sound shop to get some new wires. I ended up getting some 8gauge power wire for only .50$ a foot and put that in there. There was a noticable change. The sub seemed to "flex" more...(not sure what to call it when the cone goes in and out when the bass hits). Overall I was happy with it but wondering if it would have a negative effect on the sub? Doesnt seem like overkill since 8ga is prety small but just wondering.
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
type r's are iffy. i have ran 8 gauge to them but in a friends install the weight of the wire (he had 8ga also) kept pulling them out. the easiest way is to run 4 10 or 12ga wires to the sub and dont use the jumpers. i have also seen problems with the jumpers staying in.
What do you mean by jumper??
With some help from CA.com ive decided to throw like 8-1000wrms at the typeR so should i keep the 8awg in?
12 awg is more then enough.
x2 its such short runs of wire he could get away with even 14 im sure without a difference. but I would have left what was in the box unless it was some el cheapo with thick insulation and was smaller then 12 guage
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
748
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
758
5.7RAM
5.7RAM
IL
Ilikeitloud23
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
