How does this box look for an 18" Fi Q?
Pickler
Las Vegas
It is 6.5 cufeet internally tuned to 30hz with 111 inches of port area. What is your guys thoughts on it? to much/to little port area? not enough room inside the box? just post what you think on it.
I would do a double baffle for an 18, and that would eliminate some of the bracing you have in there. Also a little on the big side port wise. I've built boxes for several Q's and have always done 12^2 per cube...
Whats that design maker called? i need to make a design
I drew it up for him. If you need one, you can PM me.
If you want to make one yourself, then there is a sticky at the top of this section. There is no program that does it. The RE Calc is used by some, but is inaccurate.
I figured with it being an 18" Fi Q, that it would need more port area, but I don't have any experience with them.
Only 12sqin per ft^3?
He is wanting to get more net volume anyways, so we will probably change the design a bit. Smaller port, more airspace.
I figured with it being an 18" Fi Q, that it would need more port area, but I don't have any experience with them.Only 12sqin per ft^3?
Well whats the program that i can draw it out?
These are decent budget subs. The box design isn’t bad at 5 cubes for these, but I’d drop it down just a little and raise port tuning up to 32...
My subs unload at full tilt @ 28 hz, They are in 3.69 cubes net tuned to 34 hz. 4 - 8's. Big box and big power.
724
10
834
Pickler
Pickler
Las Vegas
Pickler
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
