How to Hook up a Seperate Battery for system?
Donks
CO, Ohio
i have a spare car battery. do i hook it up like the regular car battery just the postitive to postitive and leave the battery ground blank.
how do i hook it up and will it hit harder since the system has its own battery?
both batteries have to be grounded. if the front battery is grounded to the frame (which it is). then ground the second battery to either the frame or run a new negative wire between the batteries.
so do i take the 4 gauge off the car battery and hook it straight to the spare battery? wont that just drain it?
You do realize if it is a regular wet cell battery that it will produce toxic fumes when charging, correct?
i guess idk i got the battery from autozone its a big car battery it came out my caprice.
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
12
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
5
174
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
Ill be wiring my next one up at the amps battery bank area and run it to the dash to keep an eye on it
Ok ill just do the two ohm for now .i have really good electrical .ill prolly just go ahead and buy a bass 8 or 12 k for now until i can get a...
4
Donks
Donks
CO, Ohio
ultimate157
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
Latest topics
