Factory Ford Nav Head Unit to External Amplifier
  • 2
Psyence
Customized
447
Canada
Hey everyone. I am not new to CA, but I am new to actually using a factory stereo NAV unit as part fo the system.
I just purchased an 08 Sport Trac Adrenalin, and the Nav Unit with Steering wheel Controls, SYNC System, Etc will do me for a while, and im just wondering what is the best thing for me to do to get a clean clear signal to a couple external amplifiers (one sub, one components)
Thanks
If you are looking for processing you can use something such as the rockford 360, the audiocontrol lc6 or the alpine piece. (650 I believe).
Or you can just use a line output converter.
Im looking for the closest thing to a high end deck signal in the end....
Any of those better than the other?
I have used the rockford and was pretty impressed by the way it sounded. I have heard mixed reviews on the others, and have no personal experience with them.
Hopefully others can chime in with their experience with the other pieces.
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
Then you need what I listed. You also need to find out if your Honda Element has an OEM amplifier or not. And if you have steering wheel controls...
836
Psyence
Customized
Psyence
Canada
mokedaddy
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
