2006 civic EX box help.........
  • 4
UNDERGROUND_BUM
HAWAII
ok so i just got a 2006 honda civic EX sedan. this is my first trunk install, I got a older model 12" mag powered by 1200 rms. im wondering how to get the best results from a car with a trunk. Which way to point sub / port have u had good results with? ive cut open the middle armrest thing to let sound in the cabin, does this help? what else could i do?
I have the 02" model which is the same. sub back port back. I've tried everything else and this configuration works best unless you fire into the cabin with the trunk sealed off (very difficult to do though, the rear deck has a ton of holes/gaps to fill in). Get the sub box as far back as you can in the trunk and put sound deadener on the trunk lid so it doesn't rattle
If you can find these in your area. Id recommend these for drop ins. They play from 40Htz on up. Sound very nice on amplified power for premium...
Thanks for the reply bass addict. I am sure with ya'lls help I'll get it tuned up. Audiobaun has been a huge help. He basically linked everything...
50
5K
Hi I have a 2006 Porsche 911 with the original PCM head unit/system. The prior owner had a Mobridge ABT2010 unit installed - it uses a Y cable...
UNDERGROUND_BUM
UNDERGROUND_BUM
HAWAII
thegreatestpenn
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
