Quick question about Frequency response
You're going to have to be more specific.
What exactly are you confused about or need further clarification on ?
The subject is a little large, so if you can give an idea of what exactly you don't understand it will give us a starting point and we can work out from there.
i just wish to know if the wider the range the sound will be better
also if the frequency response standars are the same for all speakers?
ex: is 49-21,000Hz in an infinity speaker the same as 49-21,000Hz on an alpine?.
i know it sounds obious but i want to get this clarified
i just wish to know if the wider the range the sound will be betteralso if the frequency response standars are the same for all speakers?
even when the range is the same, the levels will be different per speaker, and differ based on the install
Take the frequency range specified by the manufacturer with a block of salt. Unless there is a tolerance to go with it, it is totally meaningless. A response plot gives a much better indication of what the speaker will do for you. Plan on using a high pass crossover on your midranges in the neighborhood of 80-100 hz (for a simple system with a simple install) and pretty much any 6.5" mid will be adequate.
Yeah, I can't find gold connectors anywhere online anymore. Amazon Canada only carries brass or "red" copper. I was gonna get the Glark's set with...
874
i have no experience with component speakers. Maybe someone else can help in this area.
Nothing to add to this, Just wanted to say good luck and that I miss MiniDisc. OH!! Is that a Japanese Radio Tuner or does it get stations in the US?
590
Navy guy
head Turning
Navy guy
West Palm, FL
helotaxi
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
