joshpoints 10+ year member
I have a 300.2 Lightning audio amp. The problem is that I was listening to music and then the amp stop putting out sound. The read "protector" light turns on when the stereo is on, but the lightning bolt on the top of the amp does not. I assume it is in some safety mode. I disconnected the power wire, ground wire and remote lead wire. THen I hooked them back up. THis is a new stereo set-up. Could the problem be that I split off of the remote lead because I have two amps and ran one of the wires off the split to each amp? HOw do I reset this amp? Is there a button somewhere, the instructions ****. They don't say anything about the protector light, they just point it out on the picture as to the name of this red light. Your help is appreciated.
