liquid nails
Wow, you are ****ing stupid...
He is asking IF liquid nails will work to seal all the edges, BECAUSE he ALREADY HAS A BOTTLE sitting at home, and doesn't want to go buy something else...
You should work on your anger management.
I know what he was asking, I was merely stating that liquid nails ***** compared to other types of adhesives.
Run along, child.
Industrial grade subfloor adhesive...it can bond to wet/iced wood //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
now thats what im talkin about right there, too bad i dont build my boxes in the rain :/
Run along, child.
i had assumed his box was already built and he was just using the liquid nails he already has as most of us would probably use silicone.
I use whatever I can get my hands on. Normally I line the inside seams with the subfloor ahdesive as well since I've already got it in the gun.
I would try a ground wire from the HU to a nice solid ground location under the dash. You can use 12ga, 14ga, even use speaker wire works just...
riddla
riddla
nf
audioarsonal
MrG
    Apr 18, 2024
MrG
    Apr 18, 2024
