What Kind of Amp for a 12" Kicker l7
sjedwards84
I am buying a 12" Kicker l7 dual 2ohm
and a ported box thats 2cubes tuned to 32hz
i have 500 to spend on the box, amp and sub
so i need an amp for about 180shipped...
any ideas on what amp i should get.. i was looking at a Hifonics 1200watt amp in the classifeids of this forum but i guess some guy has dibbs on it.. so any reccomendations.. i know im not giving you much money to work with but anything would be helpful
Rings? I've had to make them before because the factory speaker mount was plastic, and I've had to make them so the windows would clear the...
You will need a wiring kit too so a little over budget. Depending on if you're going to build on this with an additional amp for rears and a sub...
112
165
It may be that they act like this because they are underpowered and the push to play them louder is causing the amp to clip the signal, which will...
sjedwards84
sjedwards84
Wichita, Kansas
mabel4life
    Apr 13, 2024
    Apr 13, 2024
