need ur profesional advise!!!
  • 1
ntenz
good day every1!!!//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
any1 here tried using CRYSTAL subwoofers?
i have 2pcs CMPX215 and m planning to join our upcoming local SPL competition here in the philippines. i need to know what type of box and volume should i use. SPL application. it will be mounted in my suzuki jimny's rear cargo space. ive already removed my back seat to accomodate these 2 woofers. both woofers wil be driven by 2 CUTTING EDGE CE1000M 1000watts@1ohm mono amplifier bridged together to produce 2100watts @ 2ohms mono. ive upgraded my alternator and installed a 240ampere LIGHTNING AUDIO battery islotor to support 5 SVR batteries. all necessary wirings and components are now in place. subwoofer box is wats left to solve.
ur advises will be highly appreciated.
thanks in advance.
//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Signal flow should be HU to DSP to amps. You would lose the ability to EQ and time align the sub with the DSP unit if you bypassed the DSP.
384
381
If you can find these in your area. Id recommend these for drop ins. They play from 40Htz on up. Sound very nice on amplified power for premium...
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
ntenz
ntenz
manila, Phil
ntenz
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
