when to adjust crank time
  • 5
THUNDERBIRD
LANSING, MI
so i just installed a hornet 564t alarm/rs in my buddies 96 ram (he thinks it is a 97 but all the wires match a 96 on the tech sheet). he previously had a horney 553t alarm/rs installed in it but the brain broke on it and it was cheaper for me to order him a new one and install it than drive 1.5 hours to detroit to have it attempted to be warrentied out but it was 4-5 years old. so anyways. got it installed just connected all the wires to the oldwires. had to install a mercury switch and the tach as the previous installer never did that. anyways worked great after i installed it, now today i was with him and wanted to check it all out to make sure everything worked great and to adjust the shock sensor up. so i go to rs it and it cranks and doesnt start. it will crank for a split sencond probly 0.6 which if factory set. i guess it will start after 2 or 3 attempts. so after all that my question is do i have to adjust the crank time up to 0.8 or 1 or 1.2 to get it to start right? i was thinking about doing it today but weather was crappy so i thought i would ask before i do it. also installed the siren from the new one under the dash for fun.
just an FYI on the year issue.... If the 10th digit of the vin is a "T" it is a 96. A "V" is a 97.
well i relearned the tach tonight then tried to rs it, it cranked then stoped then about 20 seconds later it cranked again and it started. then i stopped playing with it as he was leaving.
yes it is, yes it lights solid, i went to one of the uncommon colors at the fuel injector, and yes it did function correctly. i had a murph over at sounddomain tell me to try changing the tach jumpers, he said he has had to do it on a few dodge trucks. i had the issue on my dads caddy and it was because second starter wasnt hooked up after that it worked(not working at the moment dotn know y nor do i care at the moment)
id eq at the db you listen to the most often. our ears dont hear things the same, at different volumes. why tune at 60 dbs, when you listen to 90
10
477
Hi, I'm new here and the current car audio that I've had for a month is my first in my life, so I'm asking for your understanding 😉 I'm starting...
THUNDERBIRD
THUNDERBIRD
LANSING, MI
THUNDERBIRD
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
Latest topics
