Min Space behind subwoofer?
  • 3
ARSkemp
FI-AQ-PA-AB-Profile-MB-RD
I was thinking about making a ported enclosure for a 12" FI SSD and was wondering if their is a minimum amount of space behind the sub that is recommended.
this around the enclosure size i was looking at:
http://www.subwoofertools.com/forum/ported-box.asp?Ew=38&Eh=16&Dia=6&Xmax=21&Vd=0.14&NumW=1&Vb=2&Fb=33&Qts=&Vas=&Fs=&CE=0
the sub has a depth of 6.5" and the depth in the box would be 7.25". Would i need more depth than that?
if i do need more depth is their a way to make the port like this:
http://www.subwoofertools.com/forum/ported-box.asp?Ew=38&Eh=16&Dia=6&Xmax=21&Vd=0.14&NumW=1&Vb=1.8&Fb=33&Qts=&Vas=&Fs=&CE=0
in the space i have for it?
I would prefer to have it take of a max of 16" H x 40" W x 12" D.
The Height and Width cannot be increased (if i can get it smaller that would be great) but i really want to make the depth as small as possible. (hoping for 10" but i dont know if thats possible). It would be a bonus if i can get the 40" W smaller too cause then i can put the amp on the side.
im basically trying to make the enclosure to the recommended on FI's website:
1.8-2.5 ft^3 @ 33hz (preferably ~1.8-2)
i really dont understand how the how port size/shape works so i don't know why the port in the top link is different looking then the one in the second link.
I think they say u need atleast 2x the pole vent of ur sub min in space behind it. Don't quote me.
As far as the ports, it's port area and length that gets you a specific tunning. So no matter how you get that length, wheather you go straight back like the first, or zig zag it, as long as the port area remains the same, length and width, depth can change as long as it adds up to the port length.
If you had used the same dimensions in those 2 links, you would have gotten the same port length requirements for both style ports.
I just learned a couple of days ago that shark fin antennas are powered. Your issue may be related to that. Either the power to the antenna is...
Can you running optical into that Bit processor? Your main input for noise is going to be between the Bluetooth and the processor. If you have...
5
No don't apologize I totally understand and the information you provided helped alot
32
796
I have confirmed through JL that these subs have just over 1inch xmech. As long as there is 1inch clearance in front of the front edge of the...
ARSkemp
ARSkemp
Salas/Chico, CA
J31Rob
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
Latest topics
