Size of fuse?
Should be fused to protect the wire in case of a short...so you want something that will blow before the wire exceeds its maximum current rating.
should be about the same as the ones on the amp like if you amps has two 40amp fuses then the inline should be the same
that is what size i would reccomend.
you should only fuse to protect the amp if it has no internal fusing. So as long as the wire is adequate for the amp the amp shouldn't considered in fuse size.
I disagree. If the power wire is capable of supplying a lot more current than the amp needs it makes sense to fuse the wire closer to the amp's max current draw.
For example - running a 600w (60A) amplifier with 4 ga wire. 125A fuse would be fine, but I would suggest something 60-80. The reason being if there ever WERE a problem - there would be a much higher factor of safety with the smaller fuse vs a big one.
The fuses on the amp would still blow, unless its a pos amp.
But i guess i should have said it isn't required but Some may suggest it. You do have a valid point.
the fuse under the hood is to protect the WIRE. a fuse in front of the load is to protect the load. 4 gauge can carry a maximum of 135 amps, so fuse it at that.
So very wrong
//content.invisioncic.com/y282845/emoticons/iagree.gif.15d6c075ee8d3913ba26866d06993068.gif
Fuse anything going to the battery 150amp fuse I would do. if it shorts you saved your battery, and than you look for causes why it happen, if...
Same here. Its what my search pulls up, but its all over the place
914
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
Tesla beat Edison. Why do you think we transmit high voltage ac? Cars are low voltage dc, which is absolute worst as far as efficiency goes, but...
61
Puppet Master
Puppet Master
Fargo, ND
ultimate157
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
