I think that it's obsurd that people are actually paying for this on EGAY ($30). I have taken the liberty of doing it myself and posting it for ya, I will keep it simple.
Tools: Small eyeglass screwdriver (Ideal); Small icepick (Ghetto);
DO NOT RIP THE WIRE OUT OF THE HOLE!!!!!
Here's what I used for the job:
Here she is the D3:
Look for this harness with all the RCA jacks in it:
Find the wire that says "MUTE" Do you see the little silver dots on the harness? This is where your going to press down on to get the wire out.
While pressing down on the silver part, pull on the wire GENTLY to remove it. Once it is pulled out completly, it will have the crimp on the end of it. Once you get that wire out this is what the harness should look like:
Now, you are going to stick that wire COMPLETELY into the hole on the bottom left. (THIS IS A PAIN IN THE BUTT) If you are having trouble getting it in, make sure that you have turned the wire the opposite way that you have pulled it out to get it back in. A little metal tab should be facing the bottom.
This is what your final product should look like with the wire in the new spot.
Now once you are ready to install the HU, make sure that you ground that (MUTE) wire and the PARKING BRAKE wire. This might have taken me a total of four minutes to actually bypass.............
Here she is the D3:
