trying to get the hang of enclosure generators...
  • 5
I would avoid inverting the subs if you can in a vented box, especially with your first box.
Why do you say that??? You won't damage them. Inverting normally causes some loss in SPL and a little better cooling but thats about it.
This work for 2 w6s? theres no driver dis because im inverting them. it will be 2 of these boxes side by side.
http://www.subwoofertools.com/forum/...Fs=25.0&C E=3
This calculator is not accurate. I would suggest using winisd or doing the math by hand. Those are the only 2 ways to properly calculate a ported enclosure..
Jon
Exactly, a loss in some cases in SPL, but in my experience the subwoofer gave off some residual noise when I inverted them, but then again the sub was right next to me, I should have elaborated.
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
344
Just need to find id to get a users Manuel thanks
Yep.3012r and 33.never drop below 14.1.have the jp84 as well.solid electrical.
17
4K
Im not a fan of S.Down, and everyone knows why. I wouldnt buy a screw from them. #1. The enclosure is everything when it comes to the performance...
26
cha0
cha0
Chicompton
Trixter
MrG
    Apr 18, 2024
MrG
    Apr 18, 2024
