Port Question
  • 2
GstRdr1
I'm building a cusom box and I have a question....Can you have a port tube that extends outside of the box?? I've only built them with the port inside the box. I've heard of this being done but does it effect the sound of the box??
Well I have never heard of that being done at all nor have I ever seen it....but I'm sure that if it was done it would have so effect on the sound in some way....I mean you can't just change a port design and or lenth and expect it to sound the same as it did before you changed it....I'm willing to bet it sounds like crap....but I could be wrong since I have never heard it..
Adam
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
Personally I'd likely go slot ported with the low tuned side of the box and aero on the high tuned side. 6th orders are just big by design
7
Yep. Point A. The last 3/4 of an inch on the exit end of the port won’t count in the displacement though. Take 3/4 off your length. You also have...
812
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
887
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
590
GstRdr1
GstRdr1
St. Louis
adamawayfrommpa
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
Latest topics
