I need help PLEASE
bacista88
25
boston
i have a question. in my car i have 61/2's all around but one day my right back stop working so i went to go unplug it and put it back in and wen i put it in. all it did is **** the cone in and thats it. so then i switched the wires to see if it works and it did the same thing. does anyone know what could be wrong plz help thanx
If the cone is just getting ****** in, that means that it is getting a DC signal...not good. Could the be the speaker or part of the amp in the HU. Try switching the rear speakers, see if the other speaker does the same thing, or if it stays the same. Then you will find out if it is the HU or the speaker.
i tryed everything i bought new speakers and tried it but it does the same thing so i dont think its my speakers. but whats a HU srry im a newb at this stuff
HU = Head Unit. That is your CD player. It is possible that your amp in your head unit is blown/damaged. If you still have a warranty on it, send it in and get it fixed.
So you're planning on running active and using the amp or head unit crossover for the tweeters? Is that sub channel full range and have separate...
884
Or you can buy a bypass https://lljcustoms.com/products/2018-2021-gm-gmc-factory-anc-bypass-select-vehicles
4
925
11
361
549
bacista88
bacista88
boston
XanderMoser
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
Latest topics
