Total Noob with noob question..do I need an Amp if I run Focal K2's
  • 4
They would sound a lot better with a sub and amps. With radio power, they might sound a little clearer than the factory speakers, but you are not going to say wow.
Don't even bother running the K2's w/o an amp!
Keep your stock speakers in there till you can afford the amp because they'll sound worse then your stock system w/o an amp.
-Nick-
Thanks! It may never have made it to U.S. retail. Actually, I highly doubt it! They have diversified their product line now as can be seen on...
The next time it happens check the voltage directly at the Boss radio. If it has 12v on both the red and yellow wires and the black wire is...
623
As long as you don't run through (or in parallel with) the vehicle's factory wiring you'll be fine.
If I was set on using what you have: I would get a head unit that will play 40-50w RMS x 4. Use that for your 3.5s and 4 x 10s, or get a small...
Scoobie Newbie
Scoobie Newbie
Shilo, MB
Scoobie Newbie
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
