Kenwood DPX-510 not seeing Music Files
  • 1
veener79
I have my Kenwood DPX-510 installed and going. What I can not get to work in my USB. I am using a SANDISK Cruzer 1GB flash drive. I am running Windows Vista and most of the files are WMA and I have even done MP3 from when Media player did the rip to MP3. I am just getting an error that states "No Music" and I am using the USB cable that comes with the head unit. I am thinking I am missing just very simple that is causing this issue but I am not sure. I just did a CD and that did not work either. I am not sure what is causing this.
***edit****
I did a CD in Roxio 7 for in a Mp3 and that did work. So now my problem is just getting get the USB to work. Thanks for any help.
Never mind I found the issue. I thought I would post this incase this might help anyone else. I did not see that my Sandisk drive was not a single partition it was 2. So I had to remove the 1 partition and I was sent to go after the format to fat32.
133
So I checked the ground wire. And god*am*tt, the frekin ground wire had wiggled out of the connector. Put a new connector on and everything works...
19
445
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
509
First off, seems to me you have the specs backwards. Ignore peak, stick to RMS. Neither of them is going to do great at 60hz, that is really...
veener79
veener79
Northern IL
veener79
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
