Fiberglassing Help
jeeper07
Rebuilding&Reconstruc ting
Well i have just started my first fiberglass job //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif so far its been fun cause i like doing new projects. Any way my question is, even if my matt is overlapped should i/ is it normal to do 2 layers. I am REPLACING the kick panel not just adding a speaker enclosure so it needs to be sturdy. I dont know how hard it gets etc but i was wondering if 2 is needed or if one will do fine ill have pics after a while
fiberglass forums does a good job of answering this.. in essence...if you can push it in with your thumb (make it flex with that lil pressure) then you need to add more
45
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
152
345
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
236
jeeper07
jeeper07
Indianapolis, IN
jeeper07
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
