Jump to content
maldecido33
sub cutouts too big; easy fix?
Recommended Posts
made a box for a friend, he gave me the wrong dimensions for the sub cutout... it's already carpeted, and the cutout is too big for the sub (12" type x)
the sub doesn't fall through, but it won't be air tight as some of the mounting holes don't have wood underneath em
keep in mind it's already carpeted.... whats the easiest fix?
2006 Chevrolet Silverado - Crew Cab Z71
Kicker ZX 750.1
Four 8" RE RE's
Bought from: Jamaica2G, Ayrton, Prowler573, netherland24, tRiGgEr, BassBEAST88, HCCAfan, HOAX_1
Sold to: James Bang, dkguitarist, Scoobydoo, ~Magick_Man~, BigEM, lostsoul, sephiroth619, Skip01, squeak12, CELLERBR, bvr_j_0969, OneKrazyKeebler, negativezeroz
Traded with: Apollyon, zachzchw, jmanpc
eBay: pmk0024 - 100% positive
Share this post
Link to post
Share on other sites
Peel the carpet back off.
I can think of two options.
Replace the bafle with a piece cut properly.
Cut the hole out bigger so the sub will fit all the way through it and use it as a flush panel. And then cut a piece to go inside the baffle and mount from behind that is cut the correct size.
Follow any of that?
The bitter after-taste of a poor quality job will last far longer than
the sweetness of that cheap price!
Share this post
Link to post
what about figuring out a way to use a 12" wood ring?? maybe peel the carpet back, cut the hole bigger and mount and seal the ring in, then put the carpet back?
it's a small system.
Share this post
Link to post
Flush Mount it.
7 Deadly Sins
-Pride- Thou Shalt Not Have Pride In Thy Neighbor -Coveting- Thou Shalt Not Covet Thy Neighbor’s Wife -Lust- Thou Shalt Not Lust After Thy Neighbor’s Wife -Anger- Do Not Be Angry With Thy Neighbor’s Wife -Gluttony- Do Not Eat Thy Neighbor’s Wife...’s Popcorn -Envy- Do Not Envy your Neighbor’s Wife -Slob- Do Not Be a Slob
-PIZZA!-
Ohio State...getting owned to the maximum since 2007.
Do NOT Buy From Ikesound.com
Share this post
Link to post
Flush Mount it.
quoted for emphasis
- Kyle
:crying: No system for the moment :crying:
REFs
sundownz, teamquakecelica, stuckinok, fosgaholic218, xtremesplokc, Smoknum, MillzThaYungin, iagrdshaka, Derek Irby, AlpineAndy, reed dollaz
Share this post
Link to post
The flush mount would be great assuming that you can get the box apart to get the mounting ring inside. If you can't get it apart, you can cut the opening about two inches bigger than needed, cut a ring that will fit in the new cutout that has a hole of the correct size and finally cut a ring that the sub will flush mount in that is wide enough to fasten the new mounting ring to the box and seal the joint. Result will be a sub mounted with a trim ring.
Artificial Intelligence is no match for Natural Stupidity.
Never underestimate the power of stupid people in large numbers.
Life's tough...it's even tougher when you're stupid.
Share this post
Link to post
Flush Mount it.
Follow any of that?
Taking advice from all of this, I think I'll:
a) Cut out the hole so the sub fits all the way through, flush mounting it.
b) Cut a ring of the proper cutout diameter that is about 5-6 inches wide, to help with mounting it on the back of the baffle.
c) Cut the ring in half to form two semi-circles, which will be joined back together once inside the box.
How's that sound? Thanks for all the help!
Kicker ZX 750.1
Four 8" RE RE's
Share this post
Link to post
That sounds like a plan. Just make sure to give yourself enough room on each side of the cutout ring to support the sub.
I may make you feel but I can't make you think.
Your sperm's in the gutter -- your love's in the sink.
Share this post
Link to post
That's a pretty frickin bad-azz idea!! !:eek:
It's been years since I have been really active in car audio forums. I posted a ton about 10 years ago here on caraudio.com, termpro.com, sounddomain.com, caraudioforum.com, and a whole bunch more that I no longer remember. You may remember me. If not, you're probably just young haha. Because of the many years since I've done any selling / buying, the only person I can remember for my references is Team PSI (David Moore).
Share this post
Link to post
:word:
References:
Caraudio.com
Luckyt,Hotown,Thunder9500,Vladd,Mikeyb,kngoftheprknglot, cd6551(x3),bolognabake,dalucifer,phrozen5100, frito,bring97, avs20,Resonant18,djman37,Showrides,Fi car audio(X2),jeeper07(x2),pimpedout97x,matrxx dude(x3),flakko(x2),mega1268,powernaudio,iamamp3pimp.bamaboy,Daishi(x3).angrytrucker78,impalafan95.netherland, down,blue200sx(x2),QtrHorseThecybe,jiggy2dmax,stc1709,musclehead,NDMstang65v2,alxmlr789
Carstereos.org
Wackii,BrownNoiseBob
Explorer4x4.com
Fordexplorer157
Mp3car.com
StLB5,Coolskys05
I know there is more ill try to find them.
Share this post
Link to post
I say make a new box.
Pioneer 80PRS
2 Way active front stage
Zapco ST-4XP 4 channel front amp
Alpine Pro Type X Tweeters
NVX XSP65 mids
Alpine MRX-M55 sub amp
SSA DCON 12"
2.25cf @ 30hz
Share this post
Link to post
I had the same problem last week. What I did was cut a inch and a half ring that would hold the sub tight and go over the baffle. I just painted it black. Then glued it and screwed it on the front. Took all of ten minutes with a jig saw.
136.7 MECA
Ref:cd6551, southstylestang, QtrHorse, malic, Toxic Tuan, matthewo, bigeasy79, eBay:syfm
Share this post
Link to post
make another front baffle, carpet it and screw it over the existing hole. some silicon should be used to make it air tight. then cut a new small hole. i dont like your odds of putting a baffle in from behind
Head installer for Hamilton Audio
Macrom, Stetsom, RD and Sundown car audio
1999 Jeep Cherokee Sport
Eclipse CD3100 head unit
Steg Audio System F4 380 4ch amp
Macrom M2 6 1/2 comp set
RE RE 10
dB set up
SD3000, SPL12 143.4dB (in my 91 Sonoma)
http://www.sounddomain.com/ride/759285
Share this post
Link to post
Yea, i'd do it like above.
Even if it's just like a circle baffle that's slightly larger then the subs diameter. Doesn't have to take up the whole baffle like the original.
NOW
2007 Maxima SE
-HU: Stock
-Goodies: 15" MX + Orion 2500D = sexAYYY
Guess Im an internet nobody :uhoh:, but guess what; Im a real life somebody :).
:patrioti:
Share this post
Link to post
Create a free account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's free & easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
