T Twistid 5,000+ posts 150.5 10,090 0 in a space out of sound Dec 29, 2006 #1 i might be getting a 4chan to go with a mono amp but my headunit has only 1 set of preouts... some sort of adapter @ radioshack? is there anything fancy to seperate between the mono + stereo? Click to read more...
ultimate157 5,000+ posts Engineering Student 7,314 0 Worcester, ma Dec 29, 2006 #2 Does either amp have a pass-through?
OP T Twistid 5,000+ posts 150.5 10,090 0 in a space out of sound Dec 29, 2006 Thread Starter #3 no i dont think so
acold7dusta 10+ year member y they stealin my bucket? 1,997 0 buffalo, NY Dec 29, 2006 #4 you'll need a y-splitter to the 4 channel, and then run an rca from the line out of the 4 channel to the line in of the sub amp edit: what amps are they? most decent modern amps have pass through
OP T Twistid 5,000+ posts 150.5 10,090 0 in a space out of sound Dec 30, 2006 Thread Starter #5 wait, the infinity 611a says "Full-range preamp outputs for multi amp systems eliminate the need for noisy adapters or signal splitters " so i can just plug the 4chan into the 611a? **** should've just read up on the specs first //content.invisioncic.com/y282845/emoticons/blackeye.gif.66a1670f5aaf7f406e783a63e3387dc5.gif
