new Fi popping
scplayboy00
//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif I just got my new Fi 15' ssd flatwind the other day. I tried it out on my friends amp Sundown 1500. I know it was a little much for it but when you stuck your head up to the sub it was popping. You couldnt here it when u was sitting in the car though. Has any one ever had there's do this?
//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
it is a dual 2 ohm taking the final load down to .7. I dont have any tinsal slap because i pulled it out of the box and watched it. I think it was bottoming out. All of the gains are set right but then we turned it all the way up to see if it could take it. It took it all but that popping noise i didn't smell any coil.
It was wired at .7. I dont have any tinsal slap because i pulled it out and checked. All of the gains are right but then we turned them up to see if it could take it and it did all but the popping noise.
You must have somthing set wrong, I mean its a FI, they are the best subs in the galaxy.
They said the the Great12" challenge that the SSD's should be kept within their RMS rating because of thermal limits. AFAIK, all of the SSD's have the same motor so you were sending it too much juice.
Wow that is very very odd. Could be the wiring harness from them. Check the wires and possibly reground the stereo to another bolt in back of the...
13
Maybe your amp gain is set too high, or wasn't set properly with the head units volume adjusted properly prior to setting the gain since you...
10
ringer ringer, chicken dinner... its your headunit. gotta upgrade mine as well, does the same thing, it cannot handle the additonal speakers, just...
Yeah, I'd give them a call. They might replace it. If they do, that is huge CS. I've never known of any mfg to replace an amp because of complete...
17
It's very likely this has to do with box rise and the fact that you should test for clipping along the entire frequency range that the sub plays...
scplayboy00
scplayboy00
hartsville sc
937DYTBOI
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
Latest topics
