8053 volume w/ loudness off
  • 1
Bartak1
Nebraska
Alrighty folks, heres the deal-deck is an Eclipse 8053-. I noticed today that when I turn the loudness ON the volume functions properly, adjust the volume at a steady level etc...like any other normal HU. BUT, when I turn the loudness OFF, the volume is a little weird. When I turn the volume down suddenly, the sub volume will go UP for a very short time, and the speaker volume takes a short time to react and turn down, and when it does go down, it seems to go down almost all the way, but then back up to the volume I turned it down to in the first place. As its going down, it also seems to go down a little bit, stay at a constant volume for a short while, then go down the rest off the way.
I really dont know how to explain it, its quite strange. It does all this within aobout 1 second or less.
Wondering what the deal is?
Is this normal or is something messed up with mine. Anyone else experience this?
Thanks
what ^ said. amp gain setting info, test tones are at the very bottom...
245
Factory. 2021 Chevy Silverado custom trailboss
9
408
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
4
750
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
9
Bartak1
Bartak1
Nebraska
Bartak1
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
Latest topics
