Home stereo
89Vette
Texas
So I was looking at some home audio stuff and the most powerful sub I could find in Crutchfield was a $500 or $350... both 12" with 300 watt amps (probably max but I don't know)... Why isn't there anything louder?
Would I just need to get 2 if I wanted more bass?
How would this sound?
-Infinity bookshelf speakers
-1 or 2 12" infinity subs
-and I'm not sure about receiver yet...
or should I go with Polk?... like a 5-speaker system? or tower speakers?
That underlined part makes no sense..... but I'll guess you meant more powerful. In that case, 300w is usually plenty for most active subwoofers you will see in that price range.
Do you want surround sound? If you just want to listen to music, a stereo pair of full-range speakers is all you would need. If you want to do movies/video games in surround sound, the 5.1 setup would do well.
if you are wanting pounding, loud bass, infinity subs are not the way to go. there is much better for the money. while i enjoy infinity's line of speakers, for the lower range of equipment, their subs are not worth your time.
you would only need two subs if your room is just that big.
bookshelf speakers are fine if that's all your room will allow. 'tower' speakers are great for front/main speakers for their obvious benefit of it being like a built in speaker stand. under all that, the actual speaker components are often almost the same as a bookshelf speaker of the same product line. however, because of the larger cabinet size of floorstanding speakers, you usually get a 'bigger' sound. so basically, if your room allows floorstanding main speakers, get them instead of bookshelf.
bookshelf speakers are generally the standard for surround speakers.
develop a budget and work from there. in the price range it looks like you're going to be working with, Onkyo or Denon would be where i'd look for a receiver.
i would definitely find a local dealer so you can audition the speakers before you purchase. crutchfield can blow all sorts of smoke up your butt, but they have no idea what is going to be appealing to your ears. also, don't limit yourself to infinity or polk. they make ok stuff, but once you get up to their higher lines that are worth your time, you could've picked up a pair of better speakers for the same or less....ex: B&W
if you have a larger room, skip over the small 'satellite' speakers. they have potential for great sound, but by the time you get a set that would suit a larger room, cabinet speakers with better sound would cost the same.
I dont know if this is supposed to be posted in here So pretty weird question but does anyone know is it possible to connect a car stereo into a...
Finished the protection on the front. You could still poke something through it. I wanted to do twice as many rods, but Home Depot and lowes were...
16
Here is the plan. My car is on a bit of an incline, the nose is sitting about half a foot higher than the rear. The little bit of windshield...
6
437
I was browsing parts express. It seemed like around $180 for a 300 watt plate amp. The dimensions are not identical, new amps seem larger by a few...
5
940
I haven't had a proper home theater or home audio system in quite a few years but here's what I remember. I like both systems to perform the same...
14
89Vette
89Vette
Texas
TXST8tj
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
Latest topics
