please help me
  • 2
I was gonna get some rockfords but they are 6'' and im not to sure they would fit?//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
did you not read what I said I just want to get something a little better than the paper coned stockers im doing a full DYNAMAT XTREME install so I only got about $60 to spend on speakers
756
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
824
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
blackblazen
blackblazen
H-town tx
Slo_Ride
ttt123
    Apr 16, 2024
ttt123
    Apr 16, 2024
