screwed up hole for one of my subs.
tank65
well everything went perfect on my box............til i put one of the subs in and i cut out to much on the circle...i have no clue how i missed that but i did.
whats the easiest way to solve this problem without replacing the whole front panel?
basically the sub will sit in the hole fine but if i were to put in screw it would probably come out the side of the wood.
should i just do some predrills at a slight angle so my screws will catch all of the wood? thats the only thing i can think of right now and i think it should work.
if not, i might just have to cut a square out around the bare minimum of the cricle and just inster another piece flat with it, then glue it put some brackets on it and seal it.
but i just need some other suggestions if you got em
no , you should just not half ass it and redo the front panel
x2 //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif DO IT right the FIRST time. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
i mean if you must be lazt slap another front on top of it and recut the holes then your not tearing anything apart and you have a thicker front
Thats what I do all the time lol...recycle old boxes and sell them to friends FTW //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
same always works //content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif
you could of always glued a small piece of 3/4" mdf to the back where hole sits redrilled the hole and just use a 3/4" longer screw.
but double baffle is a good idea if you have the space.
laters
I have dealt with several blow through sub setups over the years. Forget just trying to extend the port into the cab. All that you will hear in...
You're probably right. I have two Taramps smart 3 amps and four 10 inch CT sounds tropo for bass. I'm actually going to only install one of the...
14
16
649
283
tank65
tank65
macomb. MI
tank65
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
