possible cause for tweeter 'hissing'?
  • 6
whitemdx
SoCal
Finally got my system installed using an LOC instead of trying to spliced RCA's into the factory HU supposely 'low-level' signals.
I am quite happy with how the sound of the equipment. Only problem I noticed is that when I turn the volume on the HU (factory bose HU) all the way down, there is noticable 'hissing' or 'buzzing' noise coming out of both tweeters. When the volume is turned up, it blend in with the sound, so it really doesn't bother or affect the sound. Just curious what can be the problem? I am using a David Navone LOC and tapping into the speaker inputs for signal to the amp. Could that be it? No engine noise, just from the tweets. Thanks.
That LOC has a high voltage output IIRC.
I would set or reset your gains. With the 8 volts or so it is putting out you should not need to set the gain very high.
Setting your gains properly can help to reduce system noise. Simliarly, having your gains cranked will raise the noise floor and can cause hiss to be much more audible.
Set the gains quickly last night by ears. Will use test tone and DMM later to verify. Thanks.
BTW, what does 'IIRC' stand for?
What ever happened the fb box you started?
Got the fiberglass box completed a while back, just waiting for my equipment to be replaced. Everything is in working orders now! Will have pics later today.
//content.invisioncic.com/y282845/emoticons/read.gif.ff512c499c00ed3faae9a20f4b088b29.gif
//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
Guys, the "hiss" is the noise floor.. and it's supposed to be buried in the S/N of the system. If you can hear the noise floor, then the system's gain structure is not up to your standards... Time to get a scope and test disc, and get things set correctly.
BTW, a wire cannot create a "hiss"... it's just a passive element... Hiss is not picked up in signal cables, or speaker wires, by any inductive processes I've ever seen.
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
337
Hmm.. No Bueno. Id prob be looking at another set of subs to be honest. Like some American Bass DX series. Great subs for the $. Maybe even look...
8
601
Thanks for this! Yes, there are 6.5 door speakers, front and back. I've heard them referred to as woofers but I'm sure their frequencies included...
11
Guess so Spokey! Guess we have all been ripped off then! Whatever this guy is smoking he needs to really lay off. Either that or quit going out...
18
whitemdx
whitemdx
SoCal
DBfan187
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
Latest topics
