calculating the volume of a 90deg pvc elbow?
measure the outside of the bend, then measure the inside of the bend and take the mean average, then figure it out like a strait pipe but use the mean average as the length. So for example if the outside of the bend is 6 inches and the inside is 3 inches then figure the length of the pipe to be 4.5 inches and calculate from there
You could figre an average or you could measure one side of the inside of the bend and add that to one side of the outside ofthe bend and multiply by the area of the round cross section. It should be within a ci or two of the volume of the lengh of pipe that it accounts for for port length.
just take the double integral of the funtion f(x,y)=1 with the proper bounds type I or type II (and convert to polar coordinates to make the integration easier).
at least that's what i'm going to take a quiz on in about 10 minutes, and it actually applies to this situation //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
242
Factory. 2021 Chevy Silverado custom trailboss
406
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
748
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
funkyab
funkyab
Bloomington, Indiana/Stockholm, Sweden.
Bolognablake
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
