Very Quick Question About Tuning Boxes
Ya, I was just wondering what it would be tuned to if i made it 28 or 29" or if someone can link me to a program where I can put in the dimensions and it show me
I forwarded to your email and everybody else that wants it can download it here.
Download Box Calculator Via Xluben
Below is straight from Xluben's email he sent me....
here's the excel file i made. the top part is if you have round ports, the bottom part is for one slot port on the side of the box (like moe lester designs). you should be able to figure all of this out by hand pretty easily though. once you get the final box volume, enter that and the port dimensions into winisd (you can make a project with any driver), and it will tell you the tuning.
hope that helps,
Ben
well, i hope that file helps everyone out. it has gone through a few revisions depending on the style of the box i was thinking of.
just make sure you use the round port calculator for round ports and the slot port calculator for slot ports. also, the slot port calculator is only set up for one port on the side of the box.
ok, im confused with this. Is this how its supposed to look? Did I input everything right for a 29" box?
Ok, what if I wanted it to be 29" wide and only 23" for the depth.
It's always leaned that direction. Not sure how cheap you can really get anything done these days. Deadening and custom mounting...
10
834
Did you try the red on both sides, then the white on both sides. It may be a bad cable.
11
"I don't have any crossovers" You'll need one to filter out the low frequencies leading to your sub woofer. They'll produce no sound then...
14
JakeM
JakeM
Houston
xluben
Bobbytwonames
    Apr 20, 2024
Bobbytwonames
    Apr 20, 2024
Latest topics
