TS parameters for 02 Kicker l5?
  • 3
yeah. thanks for the very constructive and useful information.. It really makes my day batter. Because you think so I obviously must not have checked. It must be because you have 13,XXX posts and I have 2XX that I am incapable of looking for myself and that your first reaction should be to break forum rules and flame someone instead of leaving well enough alone with a blank response. That said. It is possable that I missed it. But all I found was archived info on other forums with a couple of them conflicting each other. So sorry for asking in a Enclosure design section about the T/S parameters of a sub. This is clearly not the right place to gain useful information.
Bassbox pro requires many t/s parameters some of which arent on the skar audio website. This is my first time searching for t/s parameters online...
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
316
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
876
DarkFox
DarkFox
Old Lyme, CT
DarkFox
Random4thGuy
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
Latest topics
