Fuse size?
  • 2
mastarecoil
Indiana
Quick question...
I plan on running 2 aura 2300 amplifierss in my new system. Each aura amp has 2 40amp fuses in it. Are these redunent and the total fuse size I should put on my battery to amplifier cable be 80 amp, or is each amplifier 80 amps and I need a 160 amp fuse for battery to amplifier?
Thanks all.
Quick question...
Thanks all.
you fuse the WIRE, not amp load...that's what the fuses on the amp are for.
Fuse anything going to the battery 150amp fuse I would do. if it shorts you saved your battery, and than you look for causes why it happen, if...
Same here. Its what my search pulls up, but its all over the place
914
It would be cheaper, it might be easier to find a place to mount it, and you would have a ton of options if you just do two, 3 slot fuse holders...
572
My bad, yes, I read them each as having two 4ohm coils. The JBL diagram left a bit to be desired, IMO. ;) And a double yes, thought U was talking...
mastarecoil
mastarecoil
Indiana
mastarecoil
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
