Installing a Head Unit without the stock wiring harness?
  • 6
XaznKewLguyX
bloop
3,526
SoCal
Well, my friend needs help installing his head unit, but his stock wiring harness got chopped off because someone stole his previous one. So now there is just a bunch of wires there. Anyone got any clue on how to install it?
EDIT: Car is a 1995 civic Hatch.
red power, yellow acc, black ground, orange illum.,blue with white stripe power antenna. and then just trace the speaker wires back to there places
so its pretty much color matching the wires to the new wire harness for the head unit?and the most important wires are red for power, yellow for acc, black for ground, orange for illum, and blue with white stripe for antenna?
995 Honda Civic Stereo Information
Constant 12V+ Blue/White
Switched 12V+ Yellow/Red
Ground Black
Illumination Red/Black
Dimmer n/a
Antenna Driver's Pillar
Front Speakers 6 1/2" Doors
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers 5 1/4" Rear Deck
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
Note that if the stock wire harness was cut off during a theft, it's very likely that there are one ore more blown fuses in the vehicle fuse box. If you have problems, check the fuses.
you can get factory wiring harnesses from decent shops, best thing to do would be to put a factory harness back in, and then if you change radios alot you don't have to do it all in car
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
for my amp ground I have it to the paneling in my trunk, secured with a bolt and a nut. I sanded as much as I could, and I used a grind wheel on...
72
6K
XaznKewLguyX
bloop
XaznKewLguyX
SoCal
teamsubgopoof
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
