Jump to content
Sign in to follow this
amartin_72
Is 14in enough port area for a 04S12L7? 500watts, 2.0@35hz
Recommended Posts
Is 14in enough port area for a 04S12L7? 500watts RMS Per sub, 2.0@35hz. Im making a truck enclosure and we can only get 4.0 ft net w/o ports from behind the seats. Im shooting for about 1.8@35hz each and i planned on using two 3" ports per side @ 35-37hz
Share this post
Link to post
Share on other sites
Even at that power level its more then likely going to have alot of port noise.
I had 28 cuin area and it made noise at 800 watt level bad with the lower notes.
Goin for 60 sq on 2 now.........
Share this post
Link to post
No sorry. You will get a lot of port noise. Maybe downgrade to a single sub in the proper enclosure size.
1 sub proper enclosure>2 subs improper enclosure.
Share this post
Link to post
Linearteam.org website predricts .04 m/s port mach, with .17 being port noise.
I have already made the box its 4.0 net. do you think it will be ok with 6 of the 15" ports? then it woul dhave 21 per sub for 40 total? I have already cut the ports to 15" lenght, 4 of them, i could cut two more and have 3 on each side, what abotu polyfill? i dont think so though. But dont the l7's like the higher tuning ..most of the kicker spec boxes and mtx boxes are tuned higher i dont know why must be ok for the drivers...?
Share this post
Link to post
I would not go higher than 37hz on a 12" driver. If you can get at least 24 square inches of port area per sub you would be fine.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Recently Browsing   0 members
    No registered users viewing this page.
