speaker baffles
  • 2
madison29
my OEM plastic speaker baffles are mounted at an angle http://www.123imagehost.com/uploads/375-88-DSC03110.JPG
I'm going to be putting dynomat and egg crate and plexiglas in the doors. but first i want to make the baffles. my question is, do i make the mdf to fit just around the speaker and still use the OEM angled baffle so it will fit in the interior door panel correctly? or do i have to remove the oem angled bezel and make the mdf just aiming the speaker straight instead of angled? http://www.123imagehost.com/uploads/375-737-DSC03112.JPG
i have a 2003 mitsunishi eclipse
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
184
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
743
I'd be willing to pay for a quality HU, if it meant that I can truly get the sound quality I need. I've seen some aftermarket ones that look...
10
761
You could do the 8" as a front sub on its own amp and use it to bridge/enhance the gap between your 12" in the rear to the midranges
588
madison29
madison29
chicago,il
Dozy_production
Bobbytwonames
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
