Port Size Check...
  • 2
Psyence
Customized
447
Canada
I have a 13W7 in a 2.3 cuft box or so (Fiberglass, checking volume later tonight) but its around that size... Im porting it to 30hz, so the port dimentions approx (till i see the exact volume) is 11.75"W x 1.75"H x 18"+/- L
This sufficient for minimal port noise?
Thanks again!
Well the 18" is approx.... I can make it longer, and ive designed the box to have an adjustable port length till I have the final...
I might have to tune to 32 hz or something in the end, but not a big deal.
The size 2.3cuft AFTER port/sub displacement.
The size is bigger than 2.4cuft, thats my low measurement, I thiink once I have the thing glassed, and fill 'er up with water, it will be closer for 2.5-2.6cuft.
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
872
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
571
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
728
708
Psyence
Customized
Psyence
Canada
psych0ticnemes1
Bobbytwonames
    Apr 20, 2024
Bobbytwonames
    Apr 20, 2024
