Help with DEH-P77DH and Sub
  • 1
wbtunick
I had a DEH-P77DH installed in my S-10 about 4 years ago and added an amp and sub about 2 years ago. Until about 4 months ago everything worked as it should, however about that time I starting noticing the sub would go in and out (work and then stop working) at random times.
In the last couple months it got worst and I discovered that when I push on the front of the headunit (right about the place where the connector from the face plate to the headunit is) the sub will work, however as soon as I stop pushing on it will stop working again. I have taken the headunit out and checked all the wiring to make sure nothing was loose, however the problems continues.
At this point I assume it is a bad connection between the faceplate and headunit (although not sure how that effects only the sub going in and out) and that the only solution is to get a new headunit). Any help, ideas or suggestions would be very much appreciated.
Thanks,
William
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
88
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
159
11
357
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
6
243
wbtunick
wbtunick
Sacramento, CA
wbtunick
1aespinoza
    Apr 24, 2024
Deepak Walia
    Apr 23, 2024
Latest topics
