Need help with powering my HU - Pioneer 7700mp
  • 2
harbo0909
Hey, I just picked up a new pioneer 7700, as my old 7400 shut off and started smoking the other day. I wired the new harness as per the schematic for the deck and my Honda civic. I have been unable to get power to my deck. I have my remote wire for my amp running through the ignition wire in the harness, and the amp is powering on. I have tried grounding the deck itself to the car as well as to the ground wire with the factory harness. I have replaced the fuse in the main compartment under the drivers side, and was told I may need to change a fuse in the compartment under the hood but am unaware which one as there is no specific one labelled radio. Any suggestions as to where to go from here or what else I may have to do would be greatly appreciated!!!
Thanks Harbo
Thanks Harbo
If you don't know which one it is, start pulling fuses (one at a time) and look for burned out ones. Also, look under the hood you may have some fuses under there as well, but start with the fuse panel in the passenger compartment...
11
259
523
https://youtube.com/@SaabUnleashed?si=-8qdxpYY0yGzrMsL Here you go. This guy does android head unit reviews. His reviews are how I found my...
7
806
If you want 5 channels of amplification you just need 5 channels of amplification. You can do this with 5 amps or 1, depends on budget and space...
harbo0909
harbo0909
Toronto
GO-N DEF
Bobbytwonames
    Apr 20, 2024
Bobbytwonames
    Apr 20, 2024
Latest topics
