Most recommended 791xv accessories?
i currently have a battery backup and a extra peizo siren. i also have the liquid switch under my hood and a tailgate switch since i have a truck. oh, also have the windows up/down module, i think its the 530T
Thats exactly what it does... incase your battery cable is cut during theft.
you know i was thinking about if you had like the big-3 and you had like 1/0 ga. wire, it would act as a backup in a way, think about if the theives did cut your regular wire your alarm would still work becuase of the big-3,it would still allow power to the system,like a redundant system
What does the windows up/down module do? Just let you roll your windows from a distance?
yes, it allows up/down from your remote. pretty much useless really, just cool to have //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Get a shitload of mini piezos. I got 8 installed under my dash yesterday so now I have 10 sirens. It's unbearable to sit in my car for more than 2 seconds. It makes you want to rip your ears out. THat's a good way to make sure they won't be in your car long //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Yeah but what should i be looking for from installation?
What do you mean? Like how do you know if its a good install or not?
Make sure everything works, best thing I can tell you.
I have backup battery, piezo sirens, DEI 530T window automation (windows go up when armed), 506T glass breakage sensor, 508D Motion detector (windows go up on first stage), 2 strobe lights under the dash, air horns under the dash, red/blue strobes on the front and rear deck, and the DEI hood lock system.
Alarm add-ons are kind of my hobby, that and I live in a risky part of philly
Also: For the install, make sure everything works (Best buy installed my first alarm and they didnt connect the dome light supervision, the remote trunk release, etc). Also, Wherever you have it installed (make sure you tell them where, best buy put mine right under hte driver knee panel, and the wires were all VERY exposed...bastards) and make sure that you cant see any of the wires. The alarm wire are mostly 18 gauge and are brightly colored, they stick out like a sore thumb as opposed to the factory wiring. Have the installers either wire loom or electrical tape all wires, and tuck them high up in the dash.
It is a completley new truck except for what is painted red. It has a TCI custom chassis, four wheel disc, four corner adjustable coil overs ...
Here are the reasons of my assumptions and why I think there is little danger in this setup. 1. Bared conductors could cause a spark that leads...
38
4K
You need to accurately and carefully measure your trunk out, and decide how much space you want to use, too. Always measure your trunk out before...
zachzchw
zachzchw
ohio
MisterGrubbs
Chris Gerrish
    Apr 25, 2024
vlusardi
    Apr 24, 2024
