Jump to content
Flipx99
cross over setting
Recommended Posts
I have the type r 5.25 crossover set. I already had them from previous car but I decided to build door pods for these. They came out decent. I have a question about the crossover. SHould it be on 0 db, 3 db, or 6 db. I left it at 0 because that os factory but what does it do if you move it?
Black cat, white cat...all that matters is that it catches mice. -Deng Xiaoing
I do homework for money. I specialize in finance. PM me for estimates.
If someone uses me as a reference, please contact me first.
Share this post
Link to post
Share on other sites
is the tweet harsh?
I had mine set on -6dB.
:confused:
Share this post
Link to post
It just attenuetes the tweeter. Basically, it allows you to adjust the volume of the tweeter. If the crossovers aren't going to be too hard to get to, then you can always change the jumper settings later. However, if your mounting them in your doors, you should probably get everything hooked up first, and play a bunch of different music that you normally listen to, while flipping the jumper to various levels to see where you like it best. Then you can go ahead and mount the door panel, if its going to be hidden.
Share this post
Link to post
:word:
This is not something we can answer over the 'net. Just set it to whatever sounds best. Plain and simple.
Share this post
Link to post
Create a free account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's free & easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
