RMS question
  • 4
Symon_say
You can't get me
I was reading old threads and found that you can overpower speakers if you have in consideration the hp on x-over i want to make my speakres sound loud, i have alpine sps-170A 40W RMS and want to know if anybody have overpower this or what do rms do you recommmend me to send and what freq put the x-over.
Thanks
I ahve always been a believer in the simple rule: more speakers blow because of not enough power then too much.
I would get a nice 75 watt per channel amp - it will not work as hard and should sound great.
I have always believed in the rule of truth: More speakers blow because of overpowering than underpowering, or because of idiots //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
It's true to a certain extent that if you have a highpass crossover (depending on what freq. and slope) vs. no xover at all, usually the one on the HP will handle more power. Lower frequency will tend to take more power to reproduce than higher frequency.
Send the speaker as much as you can. Give it headroom. Just know when to turn down the volume knob if it smells funny or makes funny noises.
I dont know how many times I have to say it //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
and you are also believing in myths //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
As Gsteg said........a speaker can mechanically handle more power with a higher crossover point. But you can never exceed the speaker's thermal limitations without damaging the speaker. Just be aware of where those limitations are.
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
812
Running wattage below RMS won't hurt anything. What the speakers get is the same thing as running an amp with higher wattage and then turning the...
14
No issues there. The amp will output depending on the speaker's impedance rating. Are you using a component x-over or is only the tweeter with x-over?
845
Deff a beautiful constructed sub. The best thing about as well, they do perform very well too and have excellent C.Service and even Tech service...
21
3K
Symon_say
You can't get me
Symon_say
Dominican Republic
squeak9798
ttt123
    Apr 16, 2024
ttt123
    Apr 16, 2024
Latest topics
