Upgrading HU power wire?
  • 5
HellyHans
Montreal
Hi,is it worth it to upgrade my HU powerwire to a little bigger gauge?
If so.. How do I run the power wire? directly off the battery with a fuse or is the fuse on the HU enough??
As my car has obviously a powerwire going from the fuse box to the radio,, I want to upgrade it.. do you recommend this or its not really worth it?
Alpine HU with 4V outs..
My alpine HU has a fan on it, but its not running while the HU is on.. is this fan suppose to work constantly or it will go on at a certain temp?
Hi,is it worth it to upgrade my HU powerwire to a little bigger gauge? If so.. How do I run the power wire? directly off the battery with a fuse or is the fuse on the HU enough??
im asuming it turns on when the hu has reached a certain temp due to noise issues
Sorry, yeah its a 9827, basic MP3 model, but has 4V outs.. I will run 4 speakers off of it... So, I doesnt matter if I run a direct power wire from the batt to it, with a fuse?
Concerning the fan.. in my manual, id does say that if it gets to hot, it will stop working and indicate heat on the screen,but I just thought the fan would work all the time to keep it cool
Glad to hear it was a simple fix and the amp is working again. The 9v reading indicated it was likely a bad connection somewhere.
Those NVX are very good indeed. I only have a leftover set because they were originally going into my brothers restomod 68 Chevelle SS and we...
418
Well, there is always a bypass that can be McGuyvered. So next time you want to tackle that task, post it. We can help.
684
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
When I stripped my factory system and started from scratch. I didn't need any adapters. I wired the new head unit wiring harness to the vehicle...
752
HellyHans
HellyHans
Montreal
HellyHans
MrG
    Apr 18, 2024
MrG
    Apr 18, 2024
