Box Question
  • 3
walkychalky
Currently I have two 12's but am upgrading to two 15" RE SX's.....they will be powered by an orion 2500d.... here is a quick sketch of the box i am using now: http://img357.imageshack.us/img357/9914/enclosure7zy.jpg
It's made with 3/4" MDF
so my question is do u think that this box will be a nice match for my new subs if i cut the holes larger so that they fit 15's? or would u suggest a whole new box?....i would like to keep this one because it fits perfectly in my Grand Cherokee and looks very nice....but i dont want my new subs to sound like **** in it....so any suggestions?....i dont know anthing about building boxes so i would have to pay for someone to build a new one.....so lemme know what your guys opinions are. Also, if anyone could let me know what the box is tuned to n its volume that'd be very helpful....i forgot what it was n dont know how to figure it out. (The calculators only confuse me)
Thanx
Looks good, RE recommends 3.5 per 15 SX for SQL, and you're giving them a little under 7.8( i dunno what ur subs displacement is, closer to 7 after displacement) for both with a tuning at about 31. pre-displacement of subs.
Wrong.
very informative
//content.invisioncic.com/y282845/emoticons/handclap.gif.0c301076f534e244f0460706894f19e0.gif
Its either 7.8 @31 or 6.3@34 depending on how u measured it.
Box = 6.73 before any displacments. Granted those are external dimmensions.
Port displacment = 0.56
Speaker displacment will be 0.36
So 5.81ft^3 after displacment. That's only 2.91ft^3 each and you will need a bigger box...
so if i wanted 3.5 cubes per sub after port and sub displacement.....tuned to about 32 Hz...... what would the LxWxH (external) have to be?....would it fit in a space thats 45x21x19?.....
could u give me the dimensions it would take.....maybe extending the length and width a lil bit....i could maybe gain an inch or two either way....or would this still not be enough?
Actually those dimmensions wrok out pretty good.
Box - 45" x 21" x 19" = 8.59
Slot Port - 17.5" x 4" x 16" = tunned to 32hz(31.83)
Each speaker will have 3.73ft^3
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
Yeah I'm in a circle right now too. I'm going to use 3/4" birch so I don't want to build it twice, stuff ain't cheap.
5
Emphasis added. The answer is, because you can also see DCR at other frequencies and because low impedance is extremely torturous on...
9
Common chambered sealed or ported is fine. Just make sure you have sufficient bracing
I played with the current setup I have and it's a sub port same side box. Seemed cleaner up but hit way harder faced back. I didn't know how much...
4
walkychalky
walkychalky
San Jose, CA
walkychalky
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
Latest topics
